メインコンテンツにスキップ
Toshiba Satellite P205-S8811 Monitor Replacement
必要な工具と部品
  1. Toshiba Satellite P205-S8811 Monitor Replacement, Battery: 手順 1、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement, Battery: 手順 1、 2の画像 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 2、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 2、 2の画像 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Monitor Replacement, Keyboard: 手順 3、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement, Keyboard: 手順 3、 2の画像 2
    • Place the head of a plastic opening tool underneath the plastic strip lining the top of the keyboard, right above the "PGUP" button.
    • Next, pull the strip up using a plastic opening tool with a light force, until it pops off.
  4. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 4、 1の画像 1
    • Lightly lift from the side that was popped up earlier in order to pop the rest of the strip off of the laptop.
  5. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 5、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 5、 2の画像 2
    • Use a #1 Phillips screwdriver to take out the four 4mm Phillips #1 screws that were underneath the plastic strip.
  6. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 6、 3の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 6、 3の画像 2 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 6、 3の画像 3
    • Be careful to not lift up on the keyboard too quickly or harshly; there is a ribbon cable connecting the keyboard and the base which may be breakable.
    • Lightly lift up on the keyboard from one of its top corners and pull it towards the screen so you can safely remove the ribbon cable.
    • At the base of the ribbon cable, there is a tiny tab that runs across the width of the connector. Flip it up. You can now pull the ribbon cable free with no resistance towards the monitor.
    • With the cable unplugged, the keyboard can be lifted away from the laptop.
  7. Toshiba Satellite P205-S8811 Monitor Replacement, Monitor: 手順 7、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement, Monitor: 手順 7、 2の画像 2
    • Unscrew the 4mm Phillips #1 screw holding the hard drive cover on.
    • Place one finger underneath the tab of the hard drive cover and lift it up with medium force to take it off.
  8. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 8、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 8、 2の画像 2
    • Grab the black tab attached to the hard drive and pull it to the left with a medium force until it pops out of its socket.
  9. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 9、 1の画像 1
    • Remove the two 8mm Phillips #1 screws from the back side of the laptop.
  10. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 10、 1の画像 1
    • Remove the four 8mm Phillips #1 screws located on the corners below the monitor.
  11. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 11、 1の画像 1
    • Remove the two 4mm Phillips #1 screws located between the screws removed in the last step.
  12. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 12、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 12、 2の画像 2
    • Unplug the black wire connecting the monitor to the motherboard by pulling it lightly towards you.
    • Unplug the black/red wire that also connects the monitor to the motherboard by pulling lightly away from you.
  13. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 13、 3の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 13、 3の画像 2 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 13、 3の画像 3
    • Remove the three colored wires (white, grey, and black) that are all connected beside each other by pulling them up lightly.
  14. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 14、 1の画像 1
    • Gently pull out the wide, white wire coming from the monitor.
  15. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 15、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 15、 2の画像 2
    • Use a plastic opening tool to loosen the top panel by placing the tool underneath the panel at several points and then lifting upwards with a medium force. You will know it is loose if it makes a loud clicking noise.
    • Place your fingers on the side of the panel closest to the monitor. Lift up on that side of the panel with a large amount of force in order to pry it off.
  16. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 16、 3の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 16、 3の画像 2 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 16、 3の画像 3
    • Remove the 8mm Phillips #1 screw located just below the large gray wire.
    • Remove the 8mm Phillips #1 screw located to the right of the left-hand speaker.
    • Remove the 4mm Phillips #1 screw located above the fan and next to the large gray wire.
  17. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 17、 2の画像 1 Toshiba Satellite P205-S8811 Monitor Replacement: 手順 17、 2の画像 2
    • Remove the large gray wire that is connected to the motherboard to the right of the fan.
    • Remove the small white/grey wire that is connected at the top of the fan.
  18. Toshiba Satellite P205-S8811 Monitor Replacement: 手順 18、 1の画像 1
    • Grabbing both sides of the monitor, gently lift the it out of place and set it aside.
終わりに
作成者
2人の作成者と共同で作成されました。
Bradley Johnson
メンバー登録日: 02/02/14
214 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014人のメンバー
CPSU-AMIDO-W14S2G8
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 916
