はじめに
If your hard drive is malfunctioning or if you want to replace it, this guide will show you how to take it out.
必要な工具と部品
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Use a #1 Phillips screwdriver to take out the 8mm Phillips #1 screw holding the hard drive panel on.
ある他の人がこのガイドを完成しました。
コメント 1 件
There is a missing step between 4 and 5.
- Remove the screw(s) that hold the HDD assembly in its compartment.
...only then can you move on to step 5.
