メインコンテンツにスキップ
Toshiba Satellite P105-S6147 Keyboard Replacement
必要な工具と部品
  1. Toshiba Satellite P105-S6147 Keyboard Replacement, Keyboard: 手順 1、 1の画像 1
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Keyboard Replacement: 手順 2、 1の画像 1
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Keyboard Replacement: 手順 3、 2の画像 1 Toshiba Satellite P105-S6147 Keyboard Replacement: 手順 3、 2の画像 2
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Keyboard Replacement: 手順 4、 3の画像 1 Toshiba Satellite P105-S6147 Keyboard Replacement: 手順 4、 3の画像 2 Toshiba Satellite P105-S6147 Keyboard Replacement: 手順 4、 3の画像 3
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Keyboard Replacement: 手順 5、 2の画像 1 Toshiba Satellite P105-S6147 Keyboard Replacement: 手順 5、 2の画像 2
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Benjamin Wilkinson
メンバー登録日: 09/21/18
905 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S1-G2, Friess Fall 2019 University of North Texas, Team S1-G2, Friess Fall 2019人のメンバー
UNT-FRIESS-F19S1G2
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 236
