メインコンテンツにスキップ
Toshiba Satellite M45 Power Button Replacement
必要な工具と部品
  1. Toshiba Satellite M45 Power Button Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite M45 Power Button Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite M45 Power Button Replacement, Battery: 手順 1、 3の画像 3
    • Turn the computer off and disconnect the power supply from the power supply port in the back of the computer.
    • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury. Remove the battery to reduce the chance of electrical shock and to prevent damage to the electrical components.
    • Slide the two battery locks to disconnect the battery.
    • Pull the battery (with casing) horizontally away from the computer to remove it.
  2. Toshiba Satellite M45 Power Button Replacement: 手順 2、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 2、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 2、 3の画像 3
    • Remove the RAM cover panel screws with a #1 Phillips screwdriver.
    • Then pry the RAM cover panel off with an opening tool.
    • Push the tabs that secure the RAM outward (away from the RAM) using your fingers. The RAM should then pop up.
    • Pull the RAM away from the connection to remove. Continue this process until all RAM sticks have been removed from the device.
  3. Toshiba Satellite M45 Power Button Replacement: 手順 3、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 3、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 3、 3の画像 3
    • Remove the Wi-Fi panel screw with a Phillips #1 screwdriver.
    • Pry the cover panel off with an opening tool.
    • Disconnect the black and white wires. Then push the tabs outward (away from the Wi-Fi card) using your fingers. The card should then pop up.
    • Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
  4. Toshiba Satellite M45 Power Button Replacement: 手順 4、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 4、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 4、 3の画像 3
    • Remove the hard drive panel screw with a Phillips #1 screwdriver.
    • Use an opening tool to pry the cover off.
    • Grasp the plastic flap on the hard drive and lift the hard drive out of its slot.
  5. Toshiba Satellite M45 Power Button Replacement: 手順 5、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 5、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 5、 3の画像 3
    • Remove the ODD screw with a Phillips #1 screwdriver.
    • Pry the ODD drive out of its slot from the side of the casing using an opening tool.
    • Pull the drive the rest of the way out of the laptop with your hands.
  6. Toshiba Satellite M45 Power Button Replacement: 手順 6、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 6、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 6、 3の画像 3
    • Pry off the panel above each side of the keyboard using an opening tool.
    • Turn the laptop screen so that it is horizontal with the laptop base.
    • Remove the clips on the screen hinges that hold the panel. Take off the panel.
  7. Toshiba Satellite M45 Power Button Replacement: 手順 7、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 7、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 7、 3の画像 3
    • Remove the two screws on the upper outer edges of the keyboard with a Phillips #1 screwdriver.
    • Pry the upper outer edges of the keyboard from the laptop using an opening tool.
    • Lift the keyboard away from the laptop and remove the ribbon that connects the keyboard to the laptop base.
  8. Toshiba Satellite M45 Power Button Replacement: 手順 8、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 8、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 8、 3の画像 3
    • Pull the video cable near the left speaker upwards to disconnect the cable.
    • Pull the brown ribbon away from the connector located in the middle of the laptop base.
    • Pull the two other white ribbons away from the connector located near the top right half of the laptop base.
  9. Toshiba Satellite M45 Power Button Replacement: 手順 9、 2の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 9、 2の画像 2
    • Remove all the screws using a micro-screwdriver.
    • Remove the three additional screws located in the optical drive.
  10. Toshiba Satellite M45 Power Button Replacement: 手順 10、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 10、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 10、 3の画像 3
    • Pry the case upward using an opening tool to remove the case from the laptop base.
    • Potential for device damage: Pull the case up slowly to avoid damaging the white ribbon.
    • Disconnect the large white ribbon, and let the ribbon slide through the top half of the case as you lift the case away from the laptop base.
  11. Toshiba Satellite M45 Power Button Replacement: 手順 11、 3の画像 1 Toshiba Satellite M45 Power Button Replacement: 手順 11、 3の画像 2 Toshiba Satellite M45 Power Button Replacement: 手順 11、 3の画像 3
    • Remove the two screws located above the power button board using a Phillips #1 screwdriver.
    • Move the board slowly out of its slot using an opening tool and your index finger.
    • Pull the white ribbon upwards to disconnect the ribbon from the power button board.
終わりに
作成者
4人の作成者と共同で作成されました。
Stephen Bond
メンバー登録日: 03/12/14
158 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-3, Cichon Spring 2014 UMass Dartmouth, Team 1-3, Cichon Spring 2014人のメンバー
UMASSD-CICHON-S14S1G3
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 7,883
