メインコンテンツにスキップ
Toshiba Satellite M35X-S114 RAM Replacement
必要な工具と部品
  1. Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: 手順 1、 2の画像 1 Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: 手順 1、 2の画像 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: 手順 2、 2の画像 1 Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: 手順 2、 2の画像 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: 手順 3、 2の画像 1 Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: 手順 3、 2の画像 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: 手順 4、 3の画像 1 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: 手順 4、 3の画像 2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: 手順 4、 3の画像 3
    • Locate the RAM cover around the middle left-hand side of the device.
    • Locate the screw on the RAM cover.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
    • Carefully remove the RAM access hatch.
  5. Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: 手順 5、 2の画像 1 Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: 手順 5、 2の画像 2
    • Locate the four silver clips holding the RAM sticks.
    • There is a total of two RAM chips and four silver clips. Two silver clips hold one RAM stick. Remove one RAM stick at a time.
    • Use your fingers from separate hands to pull back the two silver clips away from the sides of the RAM stick.
    • Repeat this step for the other RAM stick.
  6. Toshiba Satellite M35X-S114 RAM Replacement: 手順 6、 1の画像 1
    • Gently pull the RAM stick out from its slot.
終わりに
作成者
3人の作成者と共同で作成されました。
Christian Mayorga
メンバー登録日: 09/09/14
219 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S2G4
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 453
