はじめに
The Hard Drive replacement process involves flipping the laptop over and locating a screw on the right-hand side of the laptop. Once this screw is removed, the hard drive can be separated from the laptop.
While hard drives can be purchased from most online retailers, you may need to search for a hard drive that is compatible for the laptop's specific model. This is because most laptops use more compact and specifically designed hard drives to fit their smaller overall size.
パーツ
パーツは必要ありません。
  1. Locate the battery near the bottom left-hand side of the device. Locate the two switches above the battery's top left corner.
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Use any finger to move the larger switch above the battery to the left and hold the switch. Use any finger to move the larger switch above the battery to the left and hold the switch.
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Place your fingernail or fingertip into the groove near the top right of the battery. Pull the battery out with your finger. Release the larger switch once the battery is out.
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  5. Locate the Hard Drive. Locate the screw near the Hard Drive. Use a Phillips 00 screwdriver to remove the 7.50mm screw.
    • Locate the Hard Drive.
    • Locate the screw near the Hard Drive.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
  6. Please note that the hard drive from the laptop used is missing. Slide the hard drive out.
    • Please note that the hard drive from the laptop used is missing.
    • Slide the hard drive out.
    • The hard drive may not slide out easily, and may require a little bit of force in order to be disconnected from the laptop.
まとめ
ある他の人がこのガイドを完成しました。
Christian Mayorga
メンバー登録日: 2014年09月09日
219 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S2G4
4 メンバー
3のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 905
