はじめに
The battery replacement process involves flipping the laptop over, locating two switches, and pressing them in order to unlock the battery from its compartment. Once unlocked, the battery can be safely pulled out from the laptop. Replacing the battery may be necessary if your current battery is defective, or if the battery has become damaged and depletes too quickly. In most cases, a replacement battery can be acquired from the device's manufacturer.
  1. Locate the battery near the bottom left-hand side of the device. Locate the two switches above the battery's top left corner.
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Use any finger to move the larger switch above the battery to the left and hold the switch. Use any finger to move the larger switch above the battery to the left and hold the switch.
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  4. Place your fingernail or fingertip into the groove near the top right of the battery. Pull the battery out with your finger. Release the larger switch once the battery is out.
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
まとめ
Nathan Jansen
メンバー登録日: 2014年09月08日
206 ポイント
1ガイドが承認済み
チーム
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S2G4
4 メンバー
3のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 252
