メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
  1. Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Remove the back panel.
  2. Locate the two clips holding the RAM chip in place. Apply pressure to each clip, pulling them away from the RAM. One end of the RAM will pop out.
    • Locate the two clips holding the RAM chip in place.
    • Apply pressure to each clip, pulling them away from the RAM.
    • One end of the RAM will pop out.
  3. Gently pull RAM out as shown. Gently pull RAM out as shown.
    • Gently pull RAM out as shown.
  4. To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • Gently push down on the RAM chip until it snaps securely into place.
終わりに
Michael Jensen
メンバー登録日: 2011年04月18日
425 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S4G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,595
