メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
パーツ
パーツは指定されていません。
  1. Unlatch the battery by pushing outward on both latches.
    • Unlatch the battery by pushing outward on both latches.
  2. Slide battery out.
    • Slide battery out.
  3. Remove the five "F2" screws with a Phillips #0 screwdriver.
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Insert the plastic opening tool above the F1 key. Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Find the screws above the F1 and INS keys. Unscrew both screws with a Phillips #0 screwdriver.
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Slowly lift the top edge of the keyboard out with your fingers. The ribbon cable located on the back of the keyboard will become accessible.
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Locate the black ribbon cable flap. Detach flap with plastic opening tool.  The ribbon cable will become free.
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Your keyboard has now been successfully removed.
    • Your keyboard has now been successfully removed.
終わりに
2 の人々がこのガイドを完成させました。
Michael Jensen
メンバー登録日: 2011年04月18日
417 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S4G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,446
