メインコンテンツにスキップ
Toshiba Satellite L855-S5119 Random Access Memory Replacement
必要な工具と部品
  1. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Random Access Memory Replacement: 手順 2、 3の画像 1 Toshiba Satellite L855-S5119 Random Access Memory Replacement: 手順 2、 3の画像 2 Toshiba Satellite L855-S5119 Random Access Memory Replacement: 手順 2、 3の画像 3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Random Access Memory Replacement: 手順 3、 2の画像 1 Toshiba Satellite L855-S5119 Random Access Memory Replacement: 手順 3、 2の画像 2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: 手順 4、 3の画像 1 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: 手順 4、 3の画像 2 Toshiba Satellite L855-S5119 Random Access Memory Replacement, Back Plate Removal: 手順 4、 3の画像 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Random Access Memory Replacement, Random Access Memory: 手順 5、 1の画像 1
    • Locate the Random Access Memory.
  6. Toshiba Satellite L855-S5119 Random Access Memory Replacement: 手順 6、 3の画像 1 Toshiba Satellite L855-S5119 Random Access Memory Replacement: 手順 6、 3の画像 2 Toshiba Satellite L855-S5119 Random Access Memory Replacement: 手順 6、 3の画像 3
    • Pull back the two retention clips holding the RAM in place allowing it to pop up.
    • Remove the RAM by pulling it from the SO-DIMM slot.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Cody Brannen
メンバー登録日: 02/12/18
207 ポイント
1ガイドが承認済み
チーム
Washington State, Team S1-G5, Lobnitz Spring 2018 Washington State, Team S1-G5, Lobnitz Spring 2018人のメンバー
WSU-LOBNITZ-S18S1G5
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 407
