メインコンテンツにスキップ
Toshiba Satellite L855-S5119 Laptop Screen Replacement
必要な工具と部品
  1. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Plate Removal: 手順 1、 3の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Plate Removal: 手順 1、 3の画像 2 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Plate Removal: 手順 1、 3の画像 3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Battery: 手順 2、 1の画像 1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  3. Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 3、 3の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 3、 3の画像 2 Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 3、 3の画像 3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  4. Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 4、 2の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 4、 2の画像 2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  5. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Optical Drive: 手順 5、 2の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Optical Drive: 手順 5、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  6. Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 6、 2の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 6、 2の画像 2
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
  7. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Hard Drive: 手順 7、 2の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Hard Drive: 手順 7、 2の画像 2
    • Unscrew the hard drive.
    • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Carefully push the hard drive away from its port. This should not require substantial force.
    • Lift the hard drive out.
    • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
    • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
  8. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Cover Removal: 手順 8、 2の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Cover Removal: 手順 8、 2の画像 2
    • Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
    • Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
  9. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Fan: 手順 9、 3の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Fan: 手順 9、 3の画像 2 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Fan: 手順 9、 3の画像 3
    • Remove the two 5mm screws on the fan assembly using a Phillips #0 screwdriver.
  10. Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 10、 3の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 10、 3の画像 2 Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 10、 3の画像 3
    • Unplug the fan's connection to the motherboard.
    • Lift the fan from the laptop.
    • Use a soft cloth to clean the dust away from where the fan was.
  11. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Laptop Screen: 手順 11、 3の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Laptop Screen: 手順 11、 3の画像 2 Toshiba Satellite L855-S5119 Laptop Screen Replacement, Laptop Screen: 手順 11、 3の画像 3
    • Remove the two screws in each speaker using the Phillips #0 Screwdriver.
    • Gently lift out the speakers out of the chassis.
  12. Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 12、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the 3mm retention screw from the display connector.
    • Unplug and remove the display connector by pulling the connector free.
  13. Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 13、 3の画像 1 Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 13、 3の画像 2 Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 13、 3の画像 3
    • Remove the screen by removing two screws from both hinges using the #0 Phillips screwdriver.
    • Once the hinges have been unscrewed separate the screen from the body containing the motherboard.
  14. Toshiba Satellite L855-S5119 Laptop Screen Replacement: 手順 14、 1の画像 1
    • The removed laptop screen should have the daughterboard and speakers attached to it via wires upon removal.
終わりに
作成者
4人の作成者と共同で作成されました。
Monte Roden
メンバー登録日: 02/14/18
465 ポイント
4のガイドは作成済み
チーム
Washington State, Team S1-G5, Lobnitz Spring 2018 Washington State, Team S1-G5, Lobnitz Spring 2018人のメンバー
WSU-LOBNITZ-S18S1G5
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 597
