メインコンテンツにスキップ
Toshiba Satellite L675D-S7016 Top Case Housing Removal
必要な工具と部品
  1. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Battery: 手順 1、 1の画像 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 2、 1の画像 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 3、 3の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 3、 3の画像 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 3、 3の画像 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Back Panel Removal: 手順 4、 1の画像 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 5、 2の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 5、 2の画像 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Hard Drive: 手順 6、 2の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Hard Drive: 手順 6、 2の画像 2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
  7. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: 手順 7、 3の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: 手順 7、 3の画像 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: 手順 7、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Spudger
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  8. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 8、 2の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 8、 2の画像 2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  9. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 9、 2の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 9、 2の画像 2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  10. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 10、 3の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 10、 3の画像 2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 10、 3の画像 3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
  11. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Top Case Housing: 手順 11、 1の画像 1
    • Remove the following screws with a Phillips #1 screwdriver.
    • Seventeen 5mm screws (recessed)
    • Three 2mm screws in the battery bay (flush-mounted)
    • Single 5mm screw does not need removal unless working on the screen
  12. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 12、 2の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 12、 2の画像 2
    • Remove five 5mm screws with the screwdriver.
  13. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 13、 2の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 13、 2の画像 2
    • Locate the trackpad connector.
    • Pull the ribbon from the connector.
  14. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 14、 2の画像 1 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 手順 14、 2の画像 2
    • Pry under the top case housing along the perimeter with a plastic opening tool.
    • Be careful and gentle with this step, the clips you are releasing here are plastic and can be broken by violent prying.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Austin Bons
メンバー登録日: 09/22/16
1,131 ポイント
8のガイドは作成済み
チーム
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016人のメンバー
UCD-OLIVER-F16S2G2
5 メンバー
10のガイドは作成済み
コメント 1 件
Great help this tutorial helped
Susan Scroggs - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 1,167
