メインコンテンツにスキップ
Toshiba Satellite L675D-S7016 RAM Replacement
必要な工具と部品
  1. Toshiba Satellite L675D-S7016 RAM Replacement, Battery: 手順 1、 1の画像 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 RAM Replacement: 手順 2、 1の画像 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 RAM Replacement: 手順 3、 3の画像 1 Toshiba Satellite L675D-S7016 RAM Replacement: 手順 3、 3の画像 2 Toshiba Satellite L675D-S7016 RAM Replacement: 手順 3、 3の画像 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 RAM Replacement, Back Panel Removal: 手順 4、 1の画像 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 RAM Replacement: 手順 5、 2の画像 1 Toshiba Satellite L675D-S7016 RAM Replacement: 手順 5、 2の画像 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 RAM Replacement, RAM: 手順 6、 3の画像 1 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: 手順 6、 3の画像 2 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: 手順 6、 3の画像 3
    • Using your fingers, spread the spring tabs holding the top stick of RAM in place.
    • Once the tabs are spread apart, the stick of RAM will pop up.
    • Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
  7. Toshiba Satellite L675D-S7016 RAM Replacement: 手順 7、 3の画像 1 Toshiba Satellite L675D-S7016 RAM Replacement: 手順 7、 3の画像 2 Toshiba Satellite L675D-S7016 RAM Replacement: 手順 7、 3の画像 3
    • Repeat the same procedure to remove the second stick of RAM.
終わりに
作成者
5人の作成者と共同で作成されました。
Austin Bons
メンバー登録日: 09/22/16
1,131 ポイント
8のガイドは作成済み
チーム
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016人のメンバー
UCD-OLIVER-F16S2G2
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 616
