はじめに
If your keyboard is unresponsive, or you are having some other issues with the hardware on the keyboard, this guide will show you how to safely remove if from the laptop. If you are unsure if the issue with your keyboard is a hardware issue, check out the troubleshooting page to find out.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Spudger$4.99
Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
ある他の人がこのガイドを完成しました。
