メインコンテンツにスキップ
Toshiba Satellite L655D-S5095 Screen Replacement
必要な工具と部品
  1. Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 手順 1、 3の画像 3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Screen Replacement: 手順 2、 1の画像 1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Screen Replacement, Keyboard: 手順 3、 1の画像 1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Screen Replacement: 手順 4、 1の画像 1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Screen Replacement: 手順 5、 2の画像 1 Toshiba Satellite L655D-S5095 Screen Replacement: 手順 5、 2の画像 2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Screen Replacement: 手順 6、 1の画像 1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Screen Replacement: 手順 7、 1の画像 1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  8. Toshiba Satellite L655D-S5095 Screen Replacement, Screen: 手順 8、 2の画像 1 Toshiba Satellite L655D-S5095 Screen Replacement, Screen: 手順 8、 2の画像 2
    • Remove stickers from four corners of laptop.
    • Remove screws underneath stickers.
  9. Toshiba Satellite L655D-S5095 Screen Replacement: 手順 9、 2の画像 1 Toshiba Satellite L655D-S5095 Screen Replacement: 手順 9、 2の画像 2
    • Use plastic opening tool to pry the hinges off.
    • Remove the screen cover.
    • Unscrew the six screws on the bottom of the screen near the top of the hinges.
    There is a large plastic cover surrounding where the keyboard was and covering the hinges. How did it come off??
    Thomas Hayes - 返信
  10. Toshiba Satellite L655D-S5095 Screen Replacement: 手順 10、 2の画像 1 Toshiba Satellite L655D-S5095 Screen Replacement: 手順 10、 2の画像 2
    • Remove cable located next to the fan.
    • Fold down screen without screen back cover to remove cable as shown.
  11. Toshiba Satellite L655D-S5095 Screen Replacement: 手順 11、 2の画像 1 Toshiba Satellite L655D-S5095 Screen Replacement: 手順 11、 2の画像 2
    • Unscrew both screws on each side of the screen.
    • Remove the screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Christopher Camara
メンバー登録日: 03/11/14
194 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-4, Calaway Spring 2014 UMass Dartmouth, Team 4-4, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S4G4
4 メンバー
2のガイドは作成済み
コメント 1 件
Que éxito esta pagina , muy gran trabajo, soy de Perú y creo que este tipo de trabajos son muy bien valorados, saludos a la distancia.
Korregan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,228
