メインコンテンツにスキップ
Toshiba Satellite L655D-S5095 DC Jack Replacement
必要な工具と部品
  1. Toshiba Satellite L655D-S5095 DC Jack Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite L655D-S5095 DC Jack Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite L655D-S5095 DC Jack Replacement, Battery: 手順 1、 3の画像 3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 2、 1の画像 1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 DC Jack Replacement, Keyboard: 手順 3、 1の画像 1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 4、 1の画像 1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 5、 2の画像 1 Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 5、 2の画像 2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 6、 1の画像 1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 7、 1の画像 1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  8. Toshiba Satellite L655D-S5095 DC Jack Replacement, RAM: 手順 8、 2の画像 1 Toshiba Satellite L655D-S5095 DC Jack Replacement, RAM: 手順 8、 2の画像 2
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  9. Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 9、 1の画像 1
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  10. Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 10、 3の画像 1 Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 10、 3の画像 2 Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 10、 3の画像 3
    • Push the two tabs outwards, away from the RAM. The RAM should spring up.
  11. Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 11、 3の画像 1 Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 11、 3の画像 2 Toshiba Satellite L655D-S5095 DC Jack Replacement: 手順 11、 3の画像 3
    • Pull the top RAM stick out gently.
    • Repeat steps 3 and 4 for the bottom RAM stick.
    • When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
  12. Toshiba Satellite L655D-S5095 DC Jack Replacement, Remove optical drive: 手順 12、 1の画像 1
    • Remove the single screw securing the optical drive, and pull the optical drive out.
  13. Toshiba Satellite L655D-S5095 DC Jack Replacement, Remove palmrest: 手順 13、 3の画像 1 Toshiba Satellite L655D-S5095 DC Jack Replacement, Remove palmrest: 手順 13、 3の画像 2 Toshiba Satellite L655D-S5095 DC Jack Replacement, Remove palmrest: 手順 13、 3の画像 3
    • Remove the eight M2.5x6.5 screws securing the palmrest to the base.
    • Remove all connectors from their sockets, except for the LCD cable. That one doesn't need to be removed.
    • Flip the laptop over and remove the twelve M2.5x6.5 screws.
    • Also be sure to remove the four short, big-headed Philips screws from under where the battery was.
    • Remove the two final screws securing the palmrest to the base, which are where the optical drive's faceplate was.
    • Now use a spudger to separate the palmrest and the base.
    • Now, you can simply flip the laptop standing on its left side, pull the connector out from where the memory cover was, and then yank the jack from the adhesive holding it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Joseph Sctbunio
メンバー登録日: 09/23/17
7,332 ポイント
42のガイドは作成済み
2 件のコメント
Terrible, terrible and terrible again. You show nothing at the end about getting the jack out. I will now know not to look at any of your repairs. Totally useless.
Dave Wiloch - 返信
I apologize for my waste of your time. However, if my guide was as terrible as you say, you could have contributed to the guide instead of leaving such a comment. It would have helped more people.
Regardless, I do agree with your point, and I do not know why I had stopped the guide this early. I usually go in-depth, and have even corrected others’ guides.
I will do better next time.
Joseph Sctbunio -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 695
