はじめに
This guide will help you replace the wireless card if it is not functioning adequately. It will instruct you to remove the cover to the wifi to gain access to the card and then replace it.
必要な工具と部品
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Remove the ribbon by flipping up the tabs and using the black tweezers to gently pull the ribbon out from both ends.
ある他の人がこのガイドを完成しました。
