はじめに
This guide will assist you in removing the display of your device. You'll need to be extra careful when removing the glass screen from your device.
必要な工具と部品
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Unscrew the four 6mm screws from each of the laptop hinges using a Philips head #00 screwdriver.
2 の人々がこのガイドを完成させました。
