メインコンテンツにスキップ
Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink
必要な工具と部品
  1. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: 手順 1、 3の画像 1 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: 手順 1、 3の画像 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: 手順 1、 3の画像 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 2、 2の画像 1 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 2、 2の画像 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 3、 3の画像 1 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 3、 3の画像 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 3、 3の画像 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: 手順 4、 3の画像 1 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: 手順 4、 3の画像 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: 手順 4、 3の画像 3
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: 手順 5、 3の画像 1 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: 手順 5、 3の画像 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: 手順 5、 3の画像 3
    • The ribbon and wire must be moved out of the way of the fan.
    • Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
    • Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
  6. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 6、 2の画像 1 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 6、 2の画像 2
    • Unscrew the two 3mm Phillips head screws on each fan using the Phillips #00 screwdriver.
  7. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 7、 3の画像 1 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 7、 3の画像 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: 手順 7、 3の画像 3
    • Unscrew the four, 3mm Phillips head screws holding the last piece to the laptop using a Phillips #00 screwdriver.
    • Gently pull the cooling fan with heat sink off the laptop and set aside.
終わりに
作成者
2人の作成者と共同で作成されました。
Noelle Dulude
メンバー登録日: 03/19/18
480 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018人のメンバー
UMASSD-PEAK-S18S3G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 556
