メインコンテンツにスキップ
Toshiba Satellite L55W-C5256 RAM Replacement
必要な工具と部品
  1. Toshiba Satellite L55W-C5256 RAM Replacement, Battery: 手順 1、 1の画像 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 RAM Replacement: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 RAM Replacement: 手順 3、 1の画像 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 RAM Replacement: 手順 4、 1の画像 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 RAM Replacement: 手順 5、 1の画像 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 RAM Replacement: 手順 6、 1の画像 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 RAM Replacement, RAM: 手順 7、 3の画像 1 Toshiba Satellite L55W-C5256 RAM Replacement, RAM: 手順 7、 3の画像 2 Toshiba Satellite L55W-C5256 RAM Replacement, RAM: 手順 7、 3の画像 3
    • Reminder: Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Using your forefinger, gently pull on the left bracket that secures the RAM to the motherboard.
    • Using your forefinger, gently pull on the right bracket that secures the RAM to the motherboard.
    • When successfully freed from the locking brackets, the RAM stick will "pop up" at a 45-degree angle.
    • Lift the RAM stick from the motherboard.
  8. Toshiba Satellite L55W-C5256 RAM Replacement: 手順 8、 1の画像 1
    • Repeat step 7 to remove the second RAM stick.
    • When replacing the RAM sticks, re-insert them at the same 45-degree angle at which they were removed.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jennifer
メンバー登録日: 09/23/19
777 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G5, Virtue Fall 2019 Western Carolina University, Team S1-G5, Virtue Fall 2019人のメンバー
WCU-VIRTUE-F19S1G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 367
