メインコンテンツにスキップ
Toshiba Satellite L505D-GS6000 Screen Replacement
必要な工具と部品
  1. Toshiba Satellite L505D-GS6000 Screen Replacement, Battery: 手順 1、 2の画像 1 Toshiba Satellite L505D-GS6000 Screen Replacement, Battery: 手順 1、 2の画像 2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 2、 1の画像 1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: 手順 3、 3の画像 1 Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: 手順 3、 3の画像 2 Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: 手順 3、 3の画像 3
    • Ensure that the battery has been removed and any wires are disconnected.
    • Open to a front facing position.
    • Remove screw coverings from casing.
    • Remove the M2 5x6 mm screws that under the screw covers that you removed using a Phillips #0 screwdriver.
    • Keep screws and covers together in a pile for easier reassembly.
  4. Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 4、 3の画像 1 Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 4、 3の画像 2 Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 4、 3の画像 3
    • Carefully pry the screen covering out of place to remove it and set it to the side.
    • It may be helpful to use a plastic opening tool to assist in removal of the screen cover.
  5. Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 5、 3の画像 1 Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 5、 3の画像 2 Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 5、 3の画像 3
    • Remove the three M2 5x6 mm screws on each side holding the screen in place, using the Phillips #0 screwdriver.
    • Gently rest the screen on the keyboard, making sure not to damage any of the wires attached to it.
  6. Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 6、 2の画像 1 Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 6、 2の画像 2
    • Disconnect wire at the base of the screen from the laptop.
    • Be very gentle as to not damage any electrical components of the computer.
  7. Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 7、 3の画像 1 Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 7、 3の画像 2 Toshiba Satellite L505D-GS6000 Screen Replacement: 手順 7、 3の画像 3
    • Peel back adhesive from the second connection to the screen and unplug the connection.
    • Remove secondary adhesive from the screen connection at the base of the screen.
    • Be cautious when removing the tape, as it will be reused for the replacement screen, so be sure not to rip it.
    • The screen is now free to be removed from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Sean Hennedy
メンバー登録日: 03/20/18
124 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018人のメンバー
UMASSD-COVINO-S18S4G2
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 667
