はじめに
This guide is to be used if your disk drive is not operational and needs to be replaced.
You should replace your disk drive if it isn’t able to read something and you tried other methods of fixing it, or if the disk drive itself won’t open.
The process is fairly simple and will only require removal of one screw.
必要な工具と部品
Flip the computer over so that the bottom is facing up.
Slide right switch above the battery so that it is in the rightwards position.
Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
ある他の人がこのガイドを完成しました。
