メインコンテンツにスキップ
Toshiba Satellite L505 Laptop Speakers Replacement
必要な工具と部品
  1. Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: 手順 1、 3の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: 手順 1、 3の画像 2 Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: 手順 1、 3の画像 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Speakers Replacement: 手順 2、 2の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement: 手順 2、 2の画像 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Speakers Replacement: 手順 3、 2の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement: 手順 3、 2の画像 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Speakers Replacement: 手順 4、 3の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement: 手順 4、 3の画像 2 Toshiba Satellite L505 Laptop Speakers Replacement: 手順 4、 3の画像 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Toshiba Satellite L505 Laptop Speakers Replacement, Optical Drive: 手順 5、 2の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement, Optical Drive: 手順 5、 2の画像 2
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Toshiba Satellite L505 Laptop Speakers Replacement: 手順 6、 2の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement: 手順 6、 2の画像 2
    • Gently slide the optical drive out of the device.
  7. Toshiba Satellite L505 Laptop Speakers Replacement, Battery: 手順 7、 1の画像 1
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: 手順 8、 3の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: 手順 8、 3の画像 2 Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: 手順 8、 3の画像 3
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Toshiba Satellite L505 Laptop Speakers Replacement: 手順 9、 2の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement: 手順 9、 2の画像 2
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Toshiba Satellite L505 Laptop Speakers Replacement: 手順 10、 3の画像 1 Toshiba Satellite L505 Laptop Speakers Replacement: 手順 10、 3の画像 2 Toshiba Satellite L505 Laptop Speakers Replacement: 手順 10、 3の画像 3
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
  11. Toshiba Satellite L505 Laptop Speakers Replacement, Speakers: 手順 11、 1の画像 1
    • Remove the Palm rest assembly and flip it over.
    • Locate the 2 speakers.
  12. Toshiba Satellite L505 Laptop Speakers Replacement: 手順 12、 1の画像 1
    • Remove the three screws.
  13. Toshiba Satellite L505 Laptop Speakers Replacement: 手順 13、 1の画像 1
    • Follow the red and white wires until they join into a plug and disconnect for easy removal of the speakers.
終わりに
作成者
3人の作成者と共同で作成されました。
Matias
メンバー登録日: 09/26/18
1,019 ポイント
9のガイドは作成済み
チーム
University of North Texas, Team S7-G1, Thompson Fall 2018 University of North Texas, Team S7-G1, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S7G1
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 16
今までの合計 665
