メインコンテンツにスキップ
Toshiba Satellite L455D-S5976 Optical Drive Replacement
必要な工具と部品
  1. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Battery: 手順 1、 1の画像 1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 2、 1の画像 1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 3、 1の画像 1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Optical Drive: 手順 4、 1の画像 1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 5、 1の画像 1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 6、 1の画像 1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 7、 1の画像 1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 8、 1の画像 1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 9、 2の画像 1 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 9、 2の画像 2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 10、 3の画像 1 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 10、 3の画像 2 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 10、 3の画像 3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 11、 1の画像 1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 12、 1の画像 1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 13、 1の画像 1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 14、 3の画像 1 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 14、 3の画像 2 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 14、 3の画像 3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 15、 1の画像 1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 手順 16、 1の画像 1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
NateJohnson
メンバー登録日: 01/26/14
1,047 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 9-26, Maness Winter 2014 Cal Poly, Team 9-26, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G26
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 1,156
