はじめに
This guide is useful when you need to replace the wifi card due to it not working properly. In this guide, you will remove the wifi cover to access and then replace the wifi card.
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
必要な工具と部品
Flip Laptop into an upside-down position.
Push latches (indicated in red) outward.
Lift battery by notch (indicated in green) to remove.
2 の人々がこのガイドを完成させました。
コメント 1 件
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
