はじめに
This guide is useful when you need to replace the wifi card due to it not working properly. In this guide, you will remove the wifi cover to access and then replace the wifi card.
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
パーツ
パーツは必要ありません。
  1. Flip Laptop into an upside-down position.
    • Flip Laptop into an upside-down position.
    • Push latches (indicated in red) outward.
    • Lift battery by notch (indicated in green) to remove.
  2. Remove the plastic cover closest  to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver. Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
    • Remove the plastic cover closest to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver.
    • Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Locate the Wifi Card on the right-hand side of compartment you just revealed Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound). Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
    • Locate the Wifi Card on the right-hand side of compartment you just revealed
    • Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
  5. Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
    • Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
  6. Gently remove the wifi card from the laptop. Gently remove the wifi card from the laptop.
    • Gently remove the wifi card from the laptop.
まとめ
Dylan Baker
メンバー登録日: 2014年03月11日
121 ポイント
1ガイドが承認済み
チーム
UMD team 2 UMD team 2人のメンバー
Community
4 メンバー
1のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 1,374
