メインコンテンツにスキップ
Toshiba Satellite L455-S5975 Fan Replacement
必要な工具と部品
  1. Toshiba Satellite L455-S5975 Fan Replacement, Keyboard: 手順 1、 2の画像 1 Toshiba Satellite L455-S5975 Fan Replacement, Keyboard: 手順 1、 2の画像 2
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Fan Replacement: 手順 2、 1の画像 1
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Fan Replacement: 手順 3、 1の画像 1
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Fan Replacement: 手順 4、 2の画像 1 Toshiba Satellite L455-S5975 Fan Replacement: 手順 4、 2の画像 2
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
  5. Toshiba Satellite L455-S5975 Fan Replacement, Fan: 手順 5、 2の画像 1 Toshiba Satellite L455-S5975 Fan Replacement, Fan: 手順 5、 2の画像 2
    • Flip the laptop over to access the battery.
    • Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
  6. Toshiba Satellite L455-S5975 Fan Replacement: 手順 6、 1の画像 1
    • Remove the twelve 10mm screws with a Phillips #00 screwdriver.
    • Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
  7. Toshiba Satellite L455-S5975 Fan Replacement: 手順 7、 1の画像 1
    • Remove the three 4mm screws with a Phillips #00 screwdriver.
  8. Toshiba Satellite L455-S5975 Fan Replacement: 手順 8、 1の画像 1
    • Flip the laptop over so it's in the right-side-up position.
    • Lift the grey plastic casing up and unhook any wires attached to the casing.
    • Remove the five 10mm screws, each with a label 'F10' next to them.
  9. Toshiba Satellite L455-S5975 Fan Replacement: 手順 9、 2の画像 1 Toshiba Satellite L455-S5975 Fan Replacement: 手順 9、 2の画像 2
    • Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
    • Disconnect the thin red wire on the right side of the motherboard.
  10. Toshiba Satellite L455-S5975 Fan Replacement: 手順 10、 1の画像 1
    • Remove the two 6mm screws with a Phillips #00 screwdriver.
  11. Toshiba Satellite L455-S5975 Fan Replacement: 手順 11、 2の画像 1 Toshiba Satellite L455-S5975 Fan Replacement: 手順 11、 2の画像 2
    • Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
    • Remove the fan.
終わりに
ある他の人がこのガイドを完成しました。
作成者
10人の作成者と共同で作成されました。
Alex Brizuela
メンバー登録日: 04/19/13
88 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 2-21, Maness Spring 2013 Cal Poly, Team 2-21, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G21
4 メンバー
5のガイドは作成済み
コメント 1 件
I've taken my Toshiba L455 apart a few times from watching a few different You Tube videos. I WISH I would've seen THIS site & demonstration then! It makes it SO MUCH easier by actually showing each & ALL of the screws that need to come out,It tells you in GREAT detail step by step of everything you need to do so that nothing's ruined in the process! In the videos like when it comes to removing the keyboard/ribbon for it,you can't see what they're doing when removing the ribbon,which was my hardest part! I actually had it all put back together to learn it wasn't put back together right(since I wasn't exactly sure how it came off!) After 3 times,I FINALLY figured it out,by myself! So even this 1 doesn't say that the white clip that comes out 2 release the ribbon goes back UNDER the ribbon when putting it back! Cuz mine came out fast so I missed how it was even in there. Hopefully this helps someone since I SO wished I had this! Lol!
pds252 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 2,960
