メインコンテンツにスキップ
はじめに
In this guide we will instruct you on how to change the optical drive of your laptop. This will be helpful if yours is broken.
パーツ
パーツは指定されていません。
ビデオの概要
  1. Unscrew 1 Phillips #0 7-mm screw on the back of the computer.
    • Unscrew 1 Phillips #0 7-mm screw on the back of the computer.
  2. Lift the plate and gently pull it away from yourself, until it is removed.
    • Lift the plate and gently pull it away from yourself, until it is removed.
  3. Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
    • Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
  4. The optical drive is partially visible and push it to the right. The optical drive should pop out on the right side, and you can gently pull it out.
    • The optical drive is partially visible and push it to the right.
    • The optical drive should pop out on the right side, and you can gently pull it out.
終わりに
Daryl Spurgeon
メンバー登録日: 2017年01月10日
601 ポイント
6のガイドは作成済み
チーム
Oakland University, Team 2-1, Ruskiewicz Winter 2017 Oakland University, Team 2-1, Ruskiewicz Winter 2017人のメンバー
OAK-RUSKIEWICZ-W17S2G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 142
