メインコンテンツにスキップ
Toshiba Satellite L45-S7423 Dial Up Modem Replacement
必要な工具と部品
  1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Battery: 手順 1、 3の画像 3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 2、 2の画像 1 Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 2、 2の画像 2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 3、 2の画像 1 Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 3、 2の画像 2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Bottom Access Panel: 手順 4、 3の画像 1 Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Bottom Access Panel: 手順 4、 3の画像 2 Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Bottom Access Panel: 手順 4、 3の画像 3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 5、 3の画像 1 Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 5、 3の画像 2 Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 5、 3の画像 3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Dial Up Modem: 手順 6、 2の画像 1 Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Dial Up Modem: 手順 6、 2の画像 2
    • Remove the two screws holding modem in place.
    • Two 3.6 mm Phillips screws.
  7. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 7、 2の画像 1 Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 7、 2の画像 2
    • Using a plastic removal tool, dislodge the modem. This separates a small connections on the underside of the modem.
  8. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 8、 3の画像 1 Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 8、 3の画像 2 Toshiba Satellite L45-S7423 Dial Up Modem Replacement: 手順 8、 3の画像 3
    • Grab the black insert connected to the modem. Gently pull the insert outwards to disconnect the cable.
終わりに
作成者
4人の作成者と共同で作成されました。
Stephen Sippel
メンバー登録日: 04/16/13
194 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S21G54
4 メンバー
18のガイドは作成済み
コメント 1 件
Does someone know anything about the modem connector connecting the modem to the motherboard? Any information like part number, name, manufacturer would be handy.
Kamil - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 874
