はじめに
The Power Jack for the Toshiba Satellite L355/L305 series is damaged after many uses and will most likely need to be replaced. In this guide you will find a permanent solution to the common problem.
In order to repair/replace the Power Jack it is necessary to disassemble the laptop.
必要な工具と部品
もう少しです!
終わりに
7 の人々がこのガイドを完成させました。
