メインコンテンツにスキップ
Toshiba Satellite L305D-S5950 Speaker Replacement
必要な工具と部品
  1. Toshiba Satellite L305D-S5950 Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 2、 2の画像 1 Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 2、 2の画像 2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 3、 2の画像 1 Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 3、 2の画像 2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 4、 1の画像 1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Speaker Replacement, Keyboard: 手順 5、 2の画像 1 Toshiba Satellite L305D-S5950 Speaker Replacement, Keyboard: 手順 5、 2の画像 2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 6、 1の画像 1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 7、 3の画像 1 Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 7、 3の画像 2 Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 7、 3の画像 3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 8、 1の画像 1
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 Speaker Replacement, Motherboard Cover: 手順 9、 2の画像 1 Toshiba Satellite L305D-S5950 Speaker Replacement, Motherboard Cover: 手順 9、 2の画像 2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 10、 3の画像 1 Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 10、 3の画像 2 Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 10、 3の画像 3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  11. Toshiba Satellite L305D-S5950 Speaker Replacement, Speaker: 手順 11、 2の画像 1 Toshiba Satellite L305D-S5950 Speaker Replacement, Speaker: 手順 11、 2の画像 2
    • Use a phillips head #00 screwdriver to remove the two 5.25mm screws.
  12. Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 12、 2の画像 1 Toshiba Satellite L305D-S5950 Speaker Replacement: 手順 12、 2の画像 2
    • Turn the keyboard housing over and disconnect the speaker power wire from the keyboard housing.
    • Remove both speakers.
終わりに
作成者
4人の作成者と共同で作成されました。
William
メンバー登録日: 03/26/14
875 ポイント
7のガイドは作成済み
チーム
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S1G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 303
