この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
In order to take the motherboard cover off the keyboard needs to be removed.
必要な工具と部品
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
Remove all 5.25mm screws from the top of the laptop.
もう少しです!
終わりに
