はじめに
In order to replace the fan in your device the hard drive, keyboard, motherboard cover, and the motherboard need to be removed.
The hard drive needs to be removed since it is connected to the motherboard through a hole bottom section of the motherboard case.
The keyboard needs to be removed due to the cable connecting it to the motherboard interfering with the removal of the top part of the motherboard case.
必要な工具と部品
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
Remove all 5.25mm screws from the top of the laptop.
Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
Unplug all the wires indicated by the orange squares.
ある他の人がこのガイドを完成しました。
