メインコンテンツにスキップ
Toshiba Satellite L305-S5946 Processor Replacement
必要な工具と部品
  1. Toshiba Satellite L305-S5946 Processor Replacement, Battery: 手順 1、 1の画像 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Processor Replacement: 手順 2、 1の画像 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Processor Replacement: 手順 3、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 3、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 3、 3の画像 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Processor Replacement, Hard Drive: 手順 4、 1の画像 1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Processor Replacement: 手順 5、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 5、 2の画像 2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Processor Replacement: 手順 6、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 6、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 6、 3の画像 3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
  7. Toshiba Satellite L305-S5946 Processor Replacement, RAM: 手順 7、 1の画像 1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  8. Toshiba Satellite L305-S5946 Processor Replacement: 手順 8、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 8、 2の画像 2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  9. Toshiba Satellite L305-S5946 Processor Replacement: 手順 9、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 9、 2の画像 2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  10. Toshiba Satellite L305-S5946 Processor Replacement: 手順 10、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 10、 2の画像 2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
  11. Toshiba Satellite L305-S5946 Processor Replacement, Keyboard: 手順 11、 1の画像 1
    • Place the laptop right-side-up so the screen faces you.
  12. Toshiba Satellite L305-S5946 Processor Replacement: 手順 12、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 12、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 12、 3の画像 3
    • Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
    • Insert the plastic opening tool at either end of the strip.
    • Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
  13. Toshiba Satellite L305-S5946 Processor Replacement: 手順 13、 1の画像 1
    • CAUTION: do not allow hardware or debris into the CPU fan and duct.
    • Remove the two 3-mm screws at the top edge of the keyboard using a Phillips #00 screwdriver.
    • These are not captive panel screws and, once loosened, will be free to move about the assembly.
  14. Toshiba Satellite L305-S5946 Processor Replacement: 手順 14、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 14、 2の画像 2
    • Pry the top of the keyboard loose from its casing using a plastic opening tool.
  15. Toshiba Satellite L305-S5946 Processor Replacement: 手順 15、 1の画像 1
    • Gently grasp the top of the keyboard and pull it up and toward the screen.
    • CAUTION: Pulling too hard could damage the black ribbon cable under the keyboard.
  16. Toshiba Satellite L305-S5946 Processor Replacement: 手順 16、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 16、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 16、 3の画像 3
    • Gently push the two tabs locking the black ribbon cable.
    • To remove the black ribbon cable from the motherboard, slide the keyboard toward the screen.
    • You may now safely separate the keyboard from the laptop.
  17. Toshiba Satellite L305-S5946 Processor Replacement, Base Housing: 手順 17、 1の画像 1
  18. Toshiba Satellite L305-S5946 Processor Replacement: 手順 18、 1の画像 1
    • For the following steps, use a Phillips #1 screwdriver.
    • Remove the twelve 6-mm screws that border the bottom of the laptop.
    • Remove the 6-mm screw located in the lower middle of the device.
    • Remove the three 3-mm screws located in the battery bay.
    • Remove the one 4-mm screw located near the RAM.
  19. Toshiba Satellite L305-S5946 Processor Replacement: 手順 19、 1の画像 1
  20. Toshiba Satellite L305-S5946 Processor Replacement: 手順 20、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
  21. Toshiba Satellite L305-S5946 Processor Replacement: 手順 21、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 21、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 21、 3の画像 3
    • Lock the white ribbon cable into place by gently pulling on the two black tabs.
    • Remove the white ribbon cable by pulling it towards you.
    • Remove the connector that has the blue, red, black, and white wires using tweezers.
  22. Toshiba Satellite L305-S5946 Processor Replacement: 手順 22、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 22、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 22、 3の画像 3
    • Separate the laptop upper casing from the lower casing by using an opening tool around the sides of the case to pry it apart.
  23. Toshiba Satellite L305-S5946 Processor Replacement, Motherboard: 手順 23、 1の画像 1
    • Remove the four 6-mm screws from the two hinge pads using a Phillips #1 screwdriver.
  24. Toshiba Satellite L305-S5946 Processor Replacement: 手順 24、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 24、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 24、 3の画像 3
    • For the following steps, use tweezers:
    • Remove the connector equipped with the black and white wire.
    • Remove the connector equipped with the black, green, red, yellow, and white wires.
    • Using your fingers, remove the large connector located at the top right corner of the motherboard, as shown.
  25. Toshiba Satellite L305-S5946 Processor Replacement: 手順 25、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 25、 2の画像 2
    • Remove the two 3-mm screws from the card equipped with black and white wires by using a Phillips #00 or Phillips #1 screwdriver.
    • These are not captive panel screws and once loosened will be free to move about the assembly.
    • Gently remove the card with your fingers.
  26. Toshiba Satellite L305-S5946 Processor Replacement: 手順 26、 1の画像 1
    • Remove the display assembly and put it aside.
  27. Toshiba Satellite L305-S5946 Processor Replacement: 手順 27、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 27、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 27、 3の画像 3
    • Slide the DVD out of the opening on the right using your fingers.
  28. Toshiba Satellite L305-S5946 Processor Replacement: 手順 28、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 28、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 28、 3の画像 3
    • Remove the power jack connector.
    • Remove the connector equipped with one red wire and one black wire.
    • This connector may be hidden beneath a cooling fan wire.
    • Remove the connector equipped with red, yellow, green, white, and black wires.
    • Remove the large connector near the fan.
    • Remove the power jack cable and socket from its housing by pulling gently.
  29. Toshiba Satellite L305-S5946 Processor Replacement: 手順 29、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 29、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 29、 3の画像 3
    • Gently push the two black tabs until they stop moving.
    • Remove the silver ribbon cable from the connectors by pulling gently.
  30. Toshiba Satellite L305-S5946 Processor Replacement: 手順 30、 1の画像 1
    • Rremove the 6-mm screw near the hard drive using a Phillips #1 screwdriver.
    • This is not a captive screw and, once loosened, will be free to move about the assembly.
  31. Toshiba Satellite L305-S5946 Processor Replacement: 手順 31、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 31、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 31、 3の画像 3
    • Remove the two 3-mm screws from the card connected to the black wire using a Phillips #00 screwdriver.
    • These are not captive screws and, once loosened, will be free to move about the assembly.
  32. Toshiba Satellite L305-S5946 Processor Replacement: 手順 32、 3の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 32、 3の画像 2 Toshiba Satellite L305-S5946 Processor Replacement: 手順 32、 3の画像 3
    • Gently lift the top right side of the motherboard. Pull it upwards to the right and away from you.
  33. Toshiba Satellite L305-S5946 Processor Replacement, Cooling Fan: 手順 33、 1の画像 1
    • Flip the motherboard over. Remove the two 3-mm screws from the fan using a Phillips #1 screwdriver.
  34. Toshiba Satellite L305-S5946 Processor Replacement: 手順 34、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 34、 2の画像 2
    • Remove the housing equipped with red, blue, and yellow wires using your fingers.
  35. Toshiba Satellite L305-S5946 Processor Replacement: 手順 35、 1の画像 1
    • Remove the fan from the heatsink using your fingers.
  36. Toshiba Satellite L305-S5946 Processor Replacement, Processor: 手順 36、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the two 3-mm screws locking the heat sink in place.
  37. Toshiba Satellite L305-S5946 Processor Replacement: 手順 37、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 37、 2の画像 2
    • Using your fingers, remove the flat piece of metal covering the heatsink.
  38. Toshiba Satellite L305-S5946 Processor Replacement: 手順 38、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 38、 2の画像 2
    • Using your hands, lift the heatsink upward to remove it.
  39. Toshiba Satellite L305-S5946 Processor Replacement: 手順 39、 1の画像 1
    • Using a 3-mm flathead screwdriver, remove the screw fastening the processor.
  40. Toshiba Satellite L305-S5946 Processor Replacement: 手順 40、 2の画像 1 Toshiba Satellite L305-S5946 Processor Replacement: 手順 40、 2の画像 2
    • Using your fingers, remove the processor.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Michael Erberich
メンバー登録日: 04/17/13
130 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 3-49, Amido Spring 2013 Cal Poly, Team 3-49, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G49
4 メンバー
19のガイドは作成済み
コメント 1 件
Although my Toshiba Laptop was not exactly the same it was close enough to be able to do all that was required. The fan and heat-sink were completely clogged and it caused an over-temp condition that would shut down the laptop. After removing and cleaning the fan etc. it now runs fine. It would have been a much riskier endeavor if you had not made such detailed instructions. Thank you.
johnott1864 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 30
今までの合計 5,919
