はじめに
Use this guide to remove or replace the screen in your Toshiba Satellite L305-S5946. This may be necessary if the screen is blank when the computer is on.
  1. Turn the laptop upside-down.
    • Turn the laptop upside-down.
    • Position the laptop so that the display hinges are facing away from you.
  2. Slide the left battery bay latch to the left.
    • Slide the left battery bay latch to the left.
    • Slide the right battery bay latch to the right and hold.
    • While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
    • Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
    • Turn each screw until you hear a click.
      • These are captive panel screws and remain with the cover.
    • Lift the hard drive cover using a non-marring plastic opening tool.
      • This will expose the hard drive.
    • Slide the hard drive to the left using your fingers.
    • Insert a plastic opening tool under the right side of the hard drive.
    • Carefully lift and remove the hard drive.
    • Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
    • Turn the screw until you hear a click.
      • This is a captive panel screw and remains with the cover.
    • Insert the plastic opening tool into the indent and lift to remove the RAM cover.
    • Use your fingernails to push the white and silver retaining clips away from each side of the RAM card.
      • The RAM card should pop up at an angle.
    • Use your fingers to gently pull the RAM card away from the computer.
    • Repeat step 9 to remove the other RAM card that may be installed.
    • Turn the laptop right-side up.
    • Lift open the laptop so that the screen faces you.
    • Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
    • Insert the plastic opening tool at either end of the strip. Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
    • Use a Philips #00 screwdriver to loosen and remove the two 3-mm screws at the top edge of the keyboard.
      • These are not captive panel screws and, once loosened, will be free to move about the assembly.
      • Be careful not to allow either fastener into the CPU fan and duct (not shown).
    • Use a plastic opening tool to pry the top of the keyboard loose from its casing.
    • Gently grasp the top of the keyboard. Pull it up and toward the screen.
    • Avoid pulling hard and damaging the black ribbon cable under the keyboard.
    • Gently push the two tabs locking the black ribbon cable.
    • Slide the keyboard toward the screen to remove the black ribbon cable from the motherboard.
    • You may now safely separate the keyboard from the laptop.
    • Turn the laptop upside-down with its hinges facing away from you.
    • Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
      • Start with the three screws on the top right corner and work clockwise. This will minimize the chances missing some of the screws.
    • Use a Phillips #1 screwdriver to remove a 6-mm screw that is located in the lower middle, as shown.
    • Use a Phillips #1 screwdriver to remove the three 3-mm screws located in the battery bay.
    • Use a Phillips #1 screwdriver to remove the one 4-mm screw located near the RAM.
    • Flip open the laptop so that the screen faces you.
    • Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
      • Be careful not to allow loosened fasteners into the CPU fan and duct (located in the upper left).
    • Gently pull on the two black tabs locking the white ribbon cable in place.
    • Pull the white ribbon cable towards you to remove it.
    • Use tweezers to remove the connector that has the blue, red, black, and white wires.
    • Use a plastic opening tool to pry the laptop's upper casing off of its lower casing. Move the opening tool around the sides of the case to help separate them.
    • Using a Philips #1 screwdriver, remove the four 6-mm screws from the two metal tabs that connect the screen to the body.
    • Using tweezers, remove two connectors: one with black and white wires and one with green, yellow, red, black, and white wires.
    • Using your fingers, remove the large connector from the top right corner of the motherboard.
    • Using the Phillips #1 or Phillips #00 screwdriver, remove the two 3-mm screws from the card with black and white wires coming off of it.
      • Our card has one screw that required a Philips #1 and one that required a Philips #00. Start with the Philips #1 and, if it doesn't fit, use the Philips #00.
    • The card should pop up. Gently remove the card with your fingers.
    • Remove the screen using your hands and put it aside.
    • Using tweezers, pry the rubber feet out of the corners of the laptop.
    • Using a Phillips #1 screwdriver, remove the four 4-mm screws at the corners of the screen.
    • Using a plastic opening tool, pry off the top of the screen casing.
    • Using a Phillips #1 screwdriver, remove the four 4-mm screw.
    • Using a Philips #1 screwdriver, remove the one 6-mm screw.
    • Using your hands, remove the small connectors from the small board attached to the bottom of the LCD screen.
    • In order to access the second connector, you will need to remove the protective plastic cover. Make sure to put this back on when installing the next screen.
    • Using a Phillips #1 screwdriver, remove the six 3-mm screws from the sides of the screen. There should be three on each side.
    • Using your hands, remove the two metal strips the screws were holding.
まとめ
ある他の人がこのガイドを完成しました。
Michael Erberich
メンバー登録日: 2013年04月17日
103 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 3-49, Amido Spring 2013 Cal Poly, Team 3-49, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G49
4 メンバー
10のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 1,769
