メインコンテンツにスキップ
Toshiba Satellite L305-S5946 Base Housing Replacement
必要な工具と部品
  1. Toshiba Satellite L305-S5946 Base Housing Replacement, Battery: 手順 1、 1の画像 1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 2、 1の画像 1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 3、 3の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 3、 3の画像 2 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 3、 3の画像 3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Base Housing Replacement, Hard Drive: 手順 4、 1の画像 1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 5、 2の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 5、 2の画像 2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 6、 3の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 6、 3の画像 2 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 6、 3の画像 3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
  7. Toshiba Satellite L305-S5946 Base Housing Replacement, RAM: 手順 7、 1の画像 1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  8. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 8、 2の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 8、 2の画像 2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  9. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 9、 2の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 9、 2の画像 2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  10. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 10、 2の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 10、 2の画像 2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
  11. Toshiba Satellite L305-S5946 Base Housing Replacement, Keyboard: 手順 11、 1の画像 1
    • Place the laptop right-side-up so the screen faces you.
  12. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 12、 3の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 12、 3の画像 2 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 12、 3の画像 3
    • Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
    • Insert the plastic opening tool at either end of the strip.
    • Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
  13. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 13、 1の画像 1
    • CAUTION: do not allow hardware or debris into the CPU fan and duct.
    • Remove the two 3-mm screws at the top edge of the keyboard using a Phillips #00 screwdriver.
    • These are not captive panel screws and, once loosened, will be free to move about the assembly.
  14. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 14、 2の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 14、 2の画像 2
    • Pry the top of the keyboard loose from its casing using a plastic opening tool.
  15. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 15、 1の画像 1
    • Gently grasp the top of the keyboard and pull it up and toward the screen.
    • CAUTION: Pulling too hard could damage the black ribbon cable under the keyboard.
  16. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 16、 3の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 16、 3の画像 2 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 16、 3の画像 3
    • Gently push the two tabs locking the black ribbon cable.
    • To remove the black ribbon cable from the motherboard, slide the keyboard toward the screen.
    • You may now safely separate the keyboard from the laptop.
  17. Toshiba Satellite L305-S5946 Base Housing Replacement, Base Housing: 手順 17、 1の画像 1
  18. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 18、 1の画像 1
    • For the following steps, use a Phillips #1 screwdriver.
    • Remove the twelve 6-mm screws that border the bottom of the laptop.
    • Remove the 6-mm screw located in the lower middle of the device.
    • Remove the three 3-mm screws located in the battery bay.
    • Remove the one 4-mm screw located near the RAM.
  19. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 19、 1の画像 1
  20. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 20、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
  21. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 21、 3の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 21、 3の画像 2 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 21、 3の画像 3
    • Lock the white ribbon cable into place by gently pulling on the two black tabs.
    • Remove the white ribbon cable by pulling it towards you.
    • Remove the connector that has the blue, red, black, and white wires using tweezers.
  22. Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 22、 3の画像 1 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 22、 3の画像 2 Toshiba Satellite L305-S5946 Base Housing Replacement: 手順 22、 3の画像 3
    • Separate the laptop upper casing from the lower casing by using an opening tool around the sides of the case to pry it apart.
終わりに
ある他の人がこのガイドを完成しました。
作成者
11人の作成者と共同で作成されました。
Michael Erberich
メンバー登録日: 04/17/13
130 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 3-49, Amido Spring 2013 Cal Poly, Team 3-49, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S3G49
4 メンバー
19のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,573
