メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Toshiba Satellite L305-S5875 Keyboard Replacement
必要な工具と部品
  1. Toshiba Satellite L305-S5875 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 2、 3の画像 1 Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 2、 3の画像 2 Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 2、 3の画像 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 手順 3、 3の画像 1 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 手順 3、 3の画像 2 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: 手順 3、 3の画像 3
    • Open the laptop so the keyboard is facing you and the locate the thin plastic cover located directly above the keyboard.
    • Using your fingers, remove this long piece of plastic gently.
    • Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 4、 1の画像 1
    • Remove the two 4.8 mm type-0 Phillips head screws located underneath the plastic cover piece.
  5. Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 5、 2の画像 1 Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 5、 2の画像 2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • DO NOT pull out the keyboard after its out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 6、 2の画像 1 Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 6、 2の画像 2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Keyboard Replacement: 手順 7、 1の画像 1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
終わりに
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
3 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Juan
メンバー登録日: 01/11/13
109 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G5
4 メンバー
10のガイドは作成済み
コメント 1 件
It's not so easy to do step 3.
Texas Chick - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 3,189
