メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Toshiba Satellite L305-S5875 Hinge Replacement
必要な工具と部品
  1. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 手順 1、 3の画像 1 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 手順 1、 3の画像 2 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: 手順 1、 3の画像 3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  2. Toshiba Satellite L305-S5875 Hinge Replacement: 手順 2、 1の画像 1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  3. Toshiba Satellite L305-S5875 Hinge Replacement: 手順 3、 2の画像 1 Toshiba Satellite L305-S5875 Hinge Replacement: 手順 3、 2の画像 2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  4. Toshiba Satellite L305-S5875 Hinge Replacement: 手順 4、 2の画像 1 Toshiba Satellite L305-S5875 Hinge Replacement: 手順 4、 2の画像 2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  5. Toshiba Satellite L305-S5875 Hinge Replacement: 手順 5、 1の画像 1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  6. Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: 手順 6、 2の画像 1 Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: 手順 6、 2の画像 2
    • Close your laptop and flip it over.
    • Remove the 13 screws circled in image 2.
  7. Toshiba Satellite L305-S5875 Hinge Replacement: 手順 7、 1の画像 1
  8. Toshiba Satellite L305-S5875 Hinge Replacement: 手順 8、 1の画像 1
    • Gently disconnect the ribbon cable.
    • Gently disconnect the multicolored cable.
  9. Toshiba Satellite L305-S5875 Hinge Replacement: 手順 9、 1の画像 1
    • Gently pull the top case from the bottom case of the laptop.
  10. Toshiba Satellite L305-S5875 Hinge Replacement: 手順 10、 2の画像 1 Toshiba Satellite L305-S5875 Hinge Replacement: 手順 10、 2の画像 2
    • Unscrew the two screws on the hinge. (Be careful to not damage nearby wires)
    • Both hinges shown, but replacing both may not be necessary.
    • Congratulations, you may now remove and replace your hinge!
    • Follow these steps in reverse order to reassemble your laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Tyler
メンバー登録日: 03/11/14
208 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-1, Calaway Spring 2014 UMass Dartmouth, Team 3-1, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S3G1
4 メンバー
6のガイドは作成済み
コメント 1 件
Will this work for a Toshiba satellite l655 model
ethanhunemuller - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 6,409
