はじめに
If the hinges become loose from wear and tear or break, creating hassle when using the computer, on your Toshiba Satellite L305-S5875, this guide walks you through how to access and tighten, or replace as needed, the hinges on your Toshiba Satellite L305-S5875.
必要な工具と部品
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
ある他の人がこのガイドを完成しました。
