この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your hard drive is corrupted or you want to install a new hard drive with more space, replacing it is fairly simple.
必要な工具と部品
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Flip the laptop over so that you can see the back. Make sure that the volume scroller is closest to you when it is flipped over.
Locate the hard drive compartment. This is in the bottom left hand side of the laptop.
Remove the two 5 mm type-0 Phillips head screws that secure the door and save them to a safe location.
Remove the hard drive cover.
