この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Welcome to the Toshiba Satellite L305-S5875 CCFL Tube Replacement guide page. This guide uses both visual and written instructions in a step by step manner to help you replace the damaged CCFL tube in your screen with a brand new one.
必要な工具と部品
Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
Gently pull the back panel approximately 1 inch away from the screen.
Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
In addition to removing the screws, remove the tape on the edge of the screen.
ある他の人がこのガイドを完成しました。
