はじめに
This guide demonstrates how to remove Toshiba Satellite L15W-B1208X speakers. Some reasons to remove the speakers might be damage, such as speaker blowouts, long periods of time without use, wire corrosion, etc. Removed speakers should be recycled. Be aware of tiny components during disassembly.
必要な工具と部品
Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
Remove the six 2 mm marked screws with a Phillips #1 screwdriver (PH1 bit).
The orange marked screw is wedged underneath the Wifi card, so be careful not to damage it when removing the screw.
Use the Phillips #1 screwdriver (PH1 bit) to carefully remove the four 2 mm screws from the top of the speakers.
