メインコンテンツにスキップ
Toshiba Satellite L15W-B1208X Sound Board Replacement
必要な工具と部品
  1. Toshiba Satellite L15W-B1208X Sound Board Replacement, Battery: 手順 1、 2の画像 1 Toshiba Satellite L15W-B1208X Sound Board Replacement, Battery: 手順 1、 2の画像 2
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 2、 3の画像 1 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 2、 3の画像 2 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 2、 3の画像 3
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 3、 3の画像 1 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 3、 3の画像 2 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 3、 3の画像 3
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 4、 3の画像 1 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 4、 3の画像 2 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 4、 3の画像 3
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
  5. Toshiba Satellite L15W-B1208X Sound Board Replacement, Sound Board: 手順 5、 2の画像 1 Toshiba Satellite L15W-B1208X Sound Board Replacement, Sound Board: 手順 5、 2の画像 2
    • Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
  6. Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 6、 3の画像 1 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 6、 3の画像 2 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using the ESD Safe Tweezers Blunt Nose gently pull on the plastic connector that attaches the speaker wiring to the soundboard to disconnect the soundboard from the laptop.
    • Gently pull the wire away from the soundboard using the ESD Safe Tweezers Blunt Nose.
  7. Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 7、 3の画像 1 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 7、 3の画像 2 Toshiba Satellite L15W-B1208X Sound Board Replacement: 手順 7、 3の画像 3
    • Gently lift the soundboard out of the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Brian Herbster
メンバー登録日: 01/26/20
374 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 168
