はじめに
This guide demonstrates how to remove a Toshiba Satellite L15W-B1208X motherboard. Reasons the motherboard might need replacing include serious operating system problems, corrosion, or problems other component replacements haven’t fixed. If the motherboard has corrosion or is damaged, be sure to wear proper hand protection, such as rubber gloves. After the motherboard is removed, take it to the nearest recycling center that accepts computer components for proper disposal.
必要な工具と部品
Use Phillips #1 screwdriver (PH1 bit) to remove the 2mm screw that secures the sound board.
Remove the six 2 mm marked screws with a Phillips #1 screwdriver (PH1 bit).
The orange marked screw is wedged underneath the Wifi card, so be careful not to damage it when removing the screw.
ある他の人がこのガイドを完成しました。
