メインコンテンツにスキップ
Toshiba Satellite E45T-A4300 Motherboard Replacement
必要な工具と部品
  1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 2、 1の画像 1
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Motherboard Replacement, Hard Drive: 手順 3、 1の画像 1
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the hard drive’s connection port with grooved tweezers.
  5. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 5、 2の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 5、 2の画像 2
    • Pull the hard drive out of the hook and remove it from the device.
  6. Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: 手順 6、 2の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: 手順 6、 2の画像 2
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  7. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 7、 1の画像 1
    • Gently disconnect the fan cable from the device.
  8. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 8、 2の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 8、 2の画像 2
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
  9. Toshiba Satellite E45T-A4300 Motherboard Replacement, Heat Sink: 手順 9、 1の画像 1
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  10. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 10、 3の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 10、 3の画像 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 10、 3の画像 3
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
  11. Toshiba Satellite E45T-A4300 Motherboard Replacement, Battery: 手順 11、 1の画像 1
    • Disconnect the battery connector from the motherboard.
  12. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 12、 1の画像 1
    • Remove the single screw Phillips #1 screw near the battery.
  13. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 13、 2の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 13、 2の画像 2
    • Remove the battery from the laptop.
  14. Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: 手順 14、 2の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: 手順 14、 2の画像 2
    • Remove the single 7 mm silver screw using a Phillips #1 screwdriver.
  15. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 15、 1の画像 1
    • Pull metal stick holder until it is upright.
  16. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 16、 2の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 16、 2の画像 2
    • Remove the 7 mm silver screw under the metal bar using the Phillips #1 screwdriver.
  17. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 17、 3の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 17、 3の画像 2 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 17、 3の画像 3
    • Disconnect the six connectors from the device.
    • For the monitor port, pull it from the black tab.
    • For the connection port with the blue strip, lift the white placeholder before pulling the blue strip out of the connection port.
  18. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 18、 2の画像 1 Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 18、 2の画像 2
    • Pull out 2 plugs out from the wireless network card.
  19. Toshiba Satellite E45T-A4300 Motherboard Replacement: 手順 19、 1の画像 1
    • Remove the motherboard from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
James Nguyen
メンバー登録日: 10/23/18
573 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 UMass Dartmouth, Team S1-G4, Simcock Fall 2018人のメンバー
UMASSD-SIMCOCK-F18S1G4
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 682
