はじめに
This guide will show users how to replace the battery in the Toshiba Satellite E45DW-C4210. It takes you step by step through the process of dissembling the laptop and reassembling it. You will need to unscrew the back then remove the back from the rest of the computer. You will also need to unscrew the battery, unplug the battery, and remove the battery. Then you will need to follow the steps in reverse order to reassemble the laptop.
必要な工具と部品
Using a Phillips #0 screwdriver, remove all nine of the screws along the outside of the bottom of the laptop.
2 の人々がこのガイドを完成させました。
