この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide is designed to help you quickly and safely replace the display screen when a problem arises. The display assembly includes the LCD, the front glass, and the display enclosure.
必要な工具と部品
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
Pry the top plastic strip from the top of the keyboard.
Peel the strip completely away from the keyboard.
Locate the four silver screws on the front panel.
Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
Rotate the computer so the screen is facing you and locate the four plastic screw covers; one at each corner of the screen
Using your fingernail, remove each cover in order to expose the screw.
ある他の人がこのガイドを完成しました。
