はじめに
The cooling fan keeps the device from overheating. If a device overheats, it can shut down.
必要なもの
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
Pry the top plastic strip from the top of the keyboard.
Peel the strip completely away from the keyboard.
Locate the four silver screws on the front panel.
Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
ある他の人がこのガイドを完成しました。
