はじめに
The charging port is where the charging cord connects into the device. If your device will not charge with the cord plugged in, it may need a new charging port.
必要なもの
Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
Pry the top plastic strip from the top of the keyboard.
Peel the strip completely away from the keyboard.
Locate the four silver screws on the front panel.
Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
2 の人々がこのガイドを完成させました。
