メインコンテンツにスキップ
Toshiba Satellite Click 2 Pro Wifi Card Replacement
必要な工具と部品
  1. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: 手順 1、 2の画像 1 Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: 手順 1、 2の画像 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 2、 3の画像 1 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 2、 3の画像 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 2、 3の画像 3
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 3、 2の画像 1 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 4、 2の画像 1 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 4、 2の画像 2
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 5、 3の画像 1 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 5、 3の画像 2 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 5、 3の画像 3
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 6、 2の画像 1 Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 6、 2の画像 2
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 7、 1の画像 1
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Wifi Card: 手順 8、 1の画像 1
    • Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
  9. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    • Remove the black and white cables attached using ESD safe tweezers.
  10. Toshiba Satellite Click 2 Pro Wifi Card Replacement: 手順 10、 1の画像 1
    • Remove wifi card.
終わりに
作成者
3人の作成者と共同で作成されました。
Paul DeOrsey
メンバー登録日: 03/10/16
893 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-3, Catania Spring 2016 UMass Dartmouth, Team 4-3, Catania Spring 2016人のメンバー
UMASSD-CATANIA-S16S4G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 468
